Hi all, I will shortly be lifting my Vega onto its refurbed trailer and I was wondering if anyone has any advice regarding how to get the correct nose wheel weight. The towing guide says no more than 100Kg on the nose wheel so I guess the fore / aft position of the keel on the trailer is fairly critical.
I have been tapping the keel and it seems like most of the weight is in the solid front section and the rear section sounds hollow - just wondering if anyone has found a "good" position for it to sit nicely on the trailer? ie directly over the axles or just in front..... or relative to the drain plug....
I am told it weighs 2.3 tons (empty) is that correct?
ps if your trailer bangs like mad when towing, its because the damper needs replacement - I did not know they had a damper and nearly replaced the whole coupling at great expense!
Thanks in advance.
John
Thanks in advance.
John
