What model and brand of depth sounder do you have? Some models like the humming bird the puck antenna can just be glued to inside of hull and does not nessarily need to be located in front of the keel it can work just as well located at the rear portion of sailboat hull. And it is not nessary to use a destructive epoxy on the antenna to hold it in place. Goop will hold it in place just fine. Mine has been in place for about 5 years now no problem. And if I need to move it or something all I need is a putty knife or spatula to scrape it from hull and peel away the goop.Jared1048 said:Probably a stupid question but I cant seem to find it! Boats on the hard so it should be easy to find looking under the boat but its been evasive.
Anyone know where its located? Im painting the bottom and don't want to put too much paint over it.
