I left the catalina at the slip for a few days while they repaired the outboard (bad impeller).
I've only had it a few weeks and it's the first time I left it in the water.
I checked on it today and found a little bit ( 1/2 inch) of water in the compartment under the step down, near the keel crank handle. I've looked at that valve right there before and still am not sure how it works.
I assume it allows the cockpit to drain when the boat is out of the water, but how does it drain when it's in the water? and where does the water go? I can't believe it there's a hole in the bottom of the boat unless it has some sort of one way valve?? Should that valve be fully closed or open?
I do know that one of the hoses comes from the removable sink, which I don't have (previous post), so that's not where the water is coming from.
Any suggestions? I'm terrified that I'm going to go back to the marina and find the boat sunk and hanging by the mooring lines.
I'm sure this sounds silly, but I don't recall seeing any kind of a drain plug like my buddy has on the back of his bass boat, so I'm wondering where the water came from, how do you get it out, and what, if anything that valve and hoses may have to do with it.
There are 2 hoses coming down from the cockpit drains to the big valve, and one coming from the unused sink drain area.
There's also a large, maybe 1.5 inch green hose coming from somewhere under the cockpit and terminated in that area near the battery. Haven't been able to track that down yet.
I hope this makes sense,
thanks and I'll post a pic of the area I'm talking about.
anthony
anthony
