Where did you wire in your solar panels?
Feb 18, 2013
9
Hunter 36 Olympia, WA
I have a 2004 Hunter 36 and I want to add solar panels. I am curious how other people have attached the charging circuit to the boat's electrical system. I am thinking I can attach it to the main center pole on the battery switch, but then I would need to add a switch so I could turn it off. I can also attach it to the positive and ground at the motor. This seems like a better option, but I am not sure. That method would let me use the battery switch to select which battery was charging.
What's the best way to attach the charge controller to the boat circuit?
Mar 11, 2009
200
Hunter 40 Saint John
When we added our solar panel ( 140 watt), the solar panel went right to the controller, then the controller went directly to the batteries. I didn't want to add another switch between them. Switch would probably get turned off by accident, and not get turned on until I realised my batteries were dead. Have been running this for 5 years now, and have had no issues, and my batteries are always charged...
Feb 18, 2013
9
...then the controller went directly to the batteries...
Does your charge controller accommodate two batteries? I don't want to create a bridge through the charging circuit. If there is only one output on the solar charger, how do you charge both batteries with a single direct connection?
Oct 25, 2011
576
Island Packet IP31 Lake St. Louis, Montreal
Jim
In my set-up I only charge the house bank. (2 group 27 batteries).
The reasoning behind that was that the I wanted to make sure that the house bank was looked after first as it runs the fridge etc. I can also use it to start the engine, should the starter battery fail or be run down.
Matt
Mar 11, 2009
200
Parallel Batteries
Your batteries should be connected in parallel, if there not then you have bigger issues, saying that all you need to do is add the positive terminal (+) to the positive terminal (+) of one battery, and attach the negative (-) terminal of the controller to the 2nd battery (-) post.
It should be no different than what goes to your panel from both batteries
Feb 18, 2013
9
It sounds like things will be simpler to wire in if I add a start battery and then put my existing batteries into a parallel bank for the house. That makes it a much larger project, however. But it doubles my house capacity so it is probably worth it.
Oct 25, 2011
576
Jim
How are your batteries currently wired? On my boat I have a dedicated starter battery, #1 on the selector switch and a dedicated house bank (2 group 27) #2 on the selector switch.
I added the second group 7 to the house bank after I bought the boat. it was a fairly simple project, easily done in an afternoon.
Matt
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
You do not need a start battery. Just hook up both batteries in parallel and attach like jdhohmann indicates. Chief
Mar 20, 2012
3,983
the best way is the proper way... get a BlueSea ACR (automatic charge relay), or equivalent, hook it up to the battery banks and connect the solar to the house bank....in conjunction with the charging systems you are already using.
regardless if you have solar or not, the ACR is a great thing to have if you have two battery banks that need charged, yet you want to keep them independent from one another at all times, except when you throw the switch to combine them... which, with an ACR installed, you should never have to do unless there is a problem with one or the other banks.
9
I currently have two group 27 deep cycle AGM batteries and a selector switch. The batteries are identical. I thought it a little odd to not have a dedicated start battery, but it looks like the factory setup.
Oct 25, 2011
576
I "dedicated battery #1 as the starter battery when I added the 2nd group 27 to battery #2.
In practice I often start the engine using battery #2. I just like knowing that if one of the batteries dies, I can still fire up the engine.
Matt
Nov 26, 2012
2,315
On a Hunter 240 a dedicated start battery is not needed unless you have an inboard. Pull start is your outboard starting backup. You consume very little power to start a motor and then it quickly puts it back in the bank. You have a huge battery bank for a 24'. Chief
Oct 25, 2011
576
Got it, thank you. I had not clued in to the outboard angle. I would wire it as advised above.
Feb 6, 1998
11,722
Umm in the original post he said he has a 2004 Hunter 36......
Nov 26, 2012
2,315
Sorry bout that! Too many guys putting in too much info! Advice still good for smaller boats. Chief
PS: His profile says 240 Hunter, no wonder I'm confused!
Feb 18, 2013
9
Sorry about that misleading profile. I was wondering how you knew about the 240. I have upgraded my profile to match the upgraded boat.
Mar 20, 2012
3,983
the group 27 batts are 12 volt, so two of them will supply the necessary voltage to the starter just fine....
but having a second bank is a great option especially if you have a decent sized solar input..
you can purchase another G27 AGM and hook it up with an ACR, then move the engine supply to it.... then keep both the shore power charger and the solar charger connected to the existing house bank.
the alternator charge circuit does not need to be moved, because either bank its connected to, both banks will be charged whenever the engine is running...
Jan 12, 2011
930
Hunter 410 full time cruiser
I have mine connected to the main DC panel via a breaker and I leave both house banks on line all the time. This also on my boat charges the start battery via the inverter switch switch because the inverter is connected to the common pole and feeds the start battery across the isolator.
