Where can i get spare parts for the shower
Magnar
Oct 27, 2005
6
- - Stavanger, Norway
I have a problem with the mechanism that is used to route water to the sink or the shower. Can anyone tell me where I can get spare parts for this?
Steve O.
RV parts
Not sure exactly what part you are talking about but when my shower valve assembly broke I got a new one at an RV dealer for about $20.
Tony
Shower diverter
The part you broke is the diverter which is lifeted up to route water to shower head The one on my 340 (2000) could not be replaced without replacing the entire sink top assembly easy job if you can open the nuyts which hold it down to the sink i got the replacement from Hunter t.
Dec 2, 2003
67
Hunter 340 N. CA
WM
Mine broke recently and I had to replace the fixture. I found an identical fixture at West Marine for about $24. The only very minor difference was that the small diverter valve that you pull up to operate the shower was a separate part from where the hose attaches. The old one was one complete piece. Installing the fauet was very quick and simple, and the new one works better than the old one. Rob
Magnar
Oct 27, 2005
6
How do I find the part?
Hi Rob! I suppose this is exactly what i need. I imagine there will be no problem ordereing this part from WM in the US. However, I have some trouble finding what I need. Did you find it on WestMarine's WEB? Do you have a part number or part description? Magnar
Magnar
Oct 27, 2005
6
Who did you contact?
Hi Tony! Who at Hunter did you contact? Did they send the part(s)? What was the price? Magnar
Jan 11, 2004
35
Hunter 340 Washington, NC
Answer to RV ?
Magnar, RV is for Recreational Vehicle also known as a Camper, Caravan or land yacht. Good luck with your shower repair. I too have a 1997 h340. I spent Saturday removing and rebedding the forward Lewmar hatch. Good luck with your shower repair. Regards, Wayne Estabrooks s/v Wind Drift
May 8, 2004
13
- - Grimstad, Norway
Boat equipment in Norway
Hey, Magnar It may be worth to check around in Skandinavia before importing from the US. The cost of transport may be considerable. You will find that Maritime in Arendal holds a lot of gear. An even larger one is Hjertmans in Sweden, which I have used several times. Both of these have web sites. The type of gear you are looking for may well be found RV stores. (Campingbiler/vogner). If what you are looking for is very Hunter specific, may be Luhrs Marine in UK or Westmar may help. Kjell Arne
Tony
Diverter
Hey Mag I got the part from hunter i called them and they knew immediately and exactly what i needed and sent it to me I used their 800 number rom the websit but i imagine that is not an option for you The fellow who suggested Luhrs Europe might be on to the best approach i have attached west page with faucetts etc for you tony
Tony
UK HUNTER
Mag...one mor thing You might try this email in UK for guidance as to sink parts on your side of the pond Tony customerservice@luhrsmarine.co.uk
Dec 2, 2003
67
Hunter 340 N. CA
Sorry...
...for the delayed response and not recognizing your distant location. You've received some great advice, but just in case you still want the West Marine model number, it is 3732138. This is a West Marine Mixer Faucet and specifically identified for use in a Head - it also includes the diverter valve. They also stock one wihtout the diverter valve so you need to be sure you get one that says "Head w/Diverter" which is the part number provided. You will find this listed on their catalog website (www.westmarine.com). The manufacturer known as "Seafit" also has the same identical faucet and I would guess they package the one for West Marine with the WM name. Best of luck! Rob
