Where can I find replacement sail slides for Hunter 23.5?
Julianna
Does anyone know where I can find new mainsail slides for a Hunter 23.5 original sail? We broke several this weekend and need to replace them. Also, the plastic cap on the stop pin in the mast is stripped, and I need to get a replacement for that as well. Thank you!
Feb 9, 2008
8
Hunter 23.5 Smith Mountain Lake
Mainsail slides
I had to replace all of my slides also. My sails were made by Doyle. I called Doyle Sails in Annapolis (410)263-4840. They were able to send them to me. Some of the guides snap in place the others are sewn in, If those are broken you will have to send your sail to a sailmaker for repair. Doyle did it for me.
Dec 2, 1999
15,184
Bainbridge International
If you broke ones at the top, I would suggest that you consider using metal ones at the top. They also sell some that are coated with something (may be teflon) and may assist in raising & lowering the main.
