When to trash house batteries?
Apr 8, 2016
114
Beneteau 361 Clipper Garrucha, Spain
Hi friends,
I am about to test my house battery bank ( 3 x 90AmpH 12v AGM ) to make sure it will service my needs this coming summer as according to the battery monitor the banks been acting a little odd this winter! Within 48 hours 13.2v had sagged to 12.8v with no draw, and dropping to 12.7v within half an hour of the engine being turned off. I guess this isn't unusual for its age. The batteries show no signs of problems, i.e. bulges or feeling hot.
I have charged and run down partially the bank a couple of times in the last few days and have left it on shore power overnight. Tomorrow after unhooking from shore power Im going to run an inverter to power up an appliance of around 330w drawing 27.5amps, if I got my sums right my house bank should last just under 5 hours before hitting 50% or 12.05v. Again, if my sums are correct this would be a perfect result for brand new batteries, mine are at least 4-5 years old. I have never run them below 12.5v and last summer they lasted 48 - 60 hours with fridge, lights and TV before needing a charge.
I understand everyones requirements will be different but I hoped a seasoned cruiser in the forum could say... " When you're only getting a 1/4 instead of 1/2 the AmpH thats the time to get your wallet out "
I have been informed its possible to " condition " AGM's by hooking up to a non intelligent charger and cooking for a few hours, being careful not to boil away electrolyte, anyone had a result with this?
As always all comments received with thanks.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
A load test is about the only way to know the capacity. Or you can do as I did: head out for a long vacation and then you discover they won't supply enough power for one night on the hook. Then you try to find new ones in a small town. But then I got lucky and they were even on sale. I should have bought a lottery ticket.
Seriously, any battery shop should be able to do a quick load test. It doesn't take long. Just bring them in with a full charge.
Ken
Unfortunately it's not that easy. Battery capacities are generally listed at their 20 hour discharge rate. Faster discharge will provide less AH's. To really do a load test look up Maine Sail's guidance on how to do the 20 hour discharge test, drawing a load of capacity/20 amps (13.5 amps if doing your whole bank at once). Also remember there is some loss in the inverter, so an appliance drawing 120 watts will actually pull more than 10 amps from the battery.
As Stu pointed out 12.7-12.8 is normal resting voltage, so you can't really tell anything from that other than the fact that none of the cells are badly shorted.
Apr 8, 2016
114
Battery manufacturer?
Hey Gunni, all 3 are Victron and guess they were all replaced at the same time from the look of them. I am hoping I can find Main Sail's discharge test too...
Feb 6, 1998
11,703
Resting voltages tell you nothing about remaining Ah capacity. I can fully charge batteries, based on specific gravity or OCV (open circuit voltage) to 100% SOC that only have 30% of rated capacity remaining. That is a100Ah battery can still be at 100% SOC but may only have 30Ah's of capacity left in it. SOC and capacity are not one in the same.
A half or quarter discharge capacity test, at the wrong discharge rate, and wrong battery temp will really tell you very little.
Capacitance testers only tell you "cranking capacity" and can be GROSSLY misleading for Ah capacity.
Are Conductance Testers Worth It? (LINK)
This article covers understanding and programming of Ah counters (battery monitors) but also discusses capacity testing your batteries.
Making Your Battery Monitor More Accurate (LINK)
Unless your AGM batteries are Lifelines they can easily be destroyed by equalizing them..
Feb 6, 1998
11,703
Excerpt from the article on making your Ah counter more accurate.
What is Ampere Hour Capacity?
The Ah capacity of deep cycle marine batteries is based on the BCI (Battery Council International) 20 hour discharge test. For a 100Ah battery this means it should deliver 5A at 77F for 20 hours before the loaded terminal voltage falls to 10.5V. This is your ideal factory rated Ah capacity, but you’ll notice two things.
The first thing that stands out is the 5A current. In order to meet the 20 hour capacity test figure, the current is held absolutely stable even as the voltage decays/falls during the test. As a battery discharges, the load it is discharged at will change the usable capacity of the bank, at that load. The only way you can get 20 hours of run time, at 77F, is at the 20 hour discharge rate. Any load greater than this and the battery will not deliver its full rated capacity. On the flip side if we draw the battery at less than the 20 hour rate we can get slightly more Ah capacity out of it.
I prefer to call this the Peukert effect. I hesitate to call it Peukert’s law because it is not a law, like Ohm’s Law is, it’s an effect that modifies usable capacity based on rate of discharge.
In order to test the battery at the 20 hour rate, and do so accurately, you ideally need to hold the discharge current steady as the voltage decays to the 10.5V cut off point. This is a tedious and imprecise process for the average DIY. There is test equipment available to conduct a proper 20 hour Ah capacity tests but they begin in the four figure price range, and take a lot of time to complete. A 20 hour test is just as it implies, 20 hours long, not including the time it took you to charge the battery and get it to a controlled temp of 75-80F.
“How do I determine my batteries 20 hour discharge rate?”
This part is easy, you divide your batteries 20 hour Ah capacity by 20, eg: 100Ah ÷ 20 = 5A. If you had a 210Ah battery the math is the same; 210 ÷ 20 = 10.5A. If you want to test for Ah capacity, which is the only test that matters for an Ah counter, then this is the formula for determining the constant-current discharge load you will use.
The second thing you will notice is the temperature. Just like the rate of discharge, battery temperature affects your usable capacity. If you do not maintain a battery temp of 75-80F, during testing, you will not arrive at or get the correct 20 hour capacity. When conducting a capacity test, in order to properly program a battery monitor, discharge current and battery temp ideally need to remain constant & stable while the battery is discharged to 10.5V. A few degrees F either way sill net a "close enough" approximation but not pin point. For most boat owners "close enough" is fine...
If you don’t start with a known & confirmed Ah capacity, your Ah counter may never give you reliable information. It simply can’t unless it is programmed well. At a bare minimum, for cooler climates, a once yearly 20 hour capacity test to 10.5V should be conducted. In warmer climates, defined as average battery temps above 80F, bi-yearly is a much better choice.
“How can I conduct an accurate 20 hour capacity test?”
20 Hour Capacity Test:
#1 Fully charge battery, equalize if possible, then allow it to rest disconnected for 24 hours
#2 Make sure battery temperature is between 75F & 80F
#3 Apply a DC load that = Ah Capacity ÷ 20 (small light bulbs and/or resistors can work)
#4 Connect an accurate digital volt meter to the positive and negative battery terminals
#5 Start DC load and a stop watch at the same time
#6 As battery voltage drops, during discharge, adjust the DC load to maintain as close to the C÷20 rate as is humanly possible
#7 Immediately stop the discharge test when battery terminal voltage hits 10.499V
#8 Note the hours and minutes of run time on the stop watch and figure your percentage of 20 hours that it ran. This is your batteries current Ah capacity or state of health as a percentage. For example if a 100Ah battery ran for 16 hours it is at 80% of its original rated capacity. Flooded lead acid batteries are considered “end of life” when they can no longer deliver 80% or more of their rating.
#9 Recharge the battery immediately at the 20 hour rate. Follow this up with equalization level voltage and measure specific gravity until all cells match. (not for non-Lifeline AGM or GEL). A long slow recharge can have a slight reforming effect on flooded batteries and can actually recover some lost capacity. It is not uncommon for a battery to have more capacity after a 20 hour test than it had going into it.
“But isn’t 10.5V bad for my batteries?”
A once yearly discharge test, done correctly, is arguably less damaging than taking your battery to 50% SOC and leaving it in that range for a day or two, or the continual PSOC cycling the average boater thinks nothing of when cruising. Regular PSOC cycling is more damaging than a once or twice yearly Ah capacity test done correctly. A proper capacity test simply counts as another deep cycle and can actually revive some lost capacity.
“Twenty hours is a long time, can I conduct an approximate 20 hour capacity test?”
Approximate Capacity Test:
#2 Make certain battery temperature is between 75F & 80F
#3 Apply a DC load for 2 hours that = Ah Capacity ÷ 20 (small light bulbs and/or resistors can work)
#4 Allow the battery to rest for at least 10 hours at 75-80F (24+ hours is significantly more accurate)
#5 *Check the specific gravity or resting open circuit voltage and compare to the manufacturers SG or SOC to OCV tables
#6 Use basic math to determine the approximate Ah capacity. For example, a 100Ah rated battery has been discharged at 5A for 2 hours. This means so you removed 10Ah’s of capacity. If the battery was in perfect health specific gravity readings or open circuit voltage readings should show the battery at 90% SOC. *If SG and OCV only show the battery at 60% SOC then the battery has lost approximately 30% of it’s Ah capacity.
*This is an approximation only and not an accurate Ah capacity test. Variances can be anywhere from 10-18% off an actual 20 hour capacity test depending upon your particular battery.
CAUTION: The only time your batteries should regularly be taken below *12.1V is during a capacity test. For regular house use, at your average house loads, your deepest loaded voltage should ideally not dip below 12.1V or better yet 12.2V. Unless you are running short duration high load device such as an inverter, windlass, electric winches, thruster, water maker etc. don’t let your bank voltage dip below 12.1V.
For certain situations, such as an off-shore passage or open ocean racing, discharging to 70-80% DOD is acceptable provided the batteries receive a proper 100% SOC re-charge as soon as you get to the destination. Discharging below 50% SOC on a regular basis, in a PSOC environment, drastically shortens battery life when compared to 50%.
*Firefly AGM, large format 2V or 6V batteries, & some GEL batteries would be an exception for regularly discharging below 50% SOC.
Apr 8, 2016
114
Main Sail, thats super, thank you. I will delay my testing till Ive read your post fully. Have a good one.
Nov 13, 2013
723
Catalina 34 Tacoma
With deference to Mainsails answers, unless you are crossing an ocean or in a remote area where it would be difficult to find replacements, and you have a dedicated starting battery, I would use them until I was unhappy with the performance. Usually not difficult to find replacements. My batteries are about the same age and still suit me just fine.
Johnb
Hunter 37-cutter Richmond CA
Yep +1 - will save a bucket of bucks in the long run.
Likes: ToddS
May 24, 2004
7,164
CC 30 South Florida
A 13.2V is a reading right after charging. After rest the voltage of a fully charged battery is 12.67V. A battery right after charge will read a higher voltage and right after a load will read a lower voltage, that is why it is recommended you take a voltage reading for the battery at rest (approx. 2 hrs after charge or load). A battery can show a voltage showing it is fully charged but its capacity to hold charge can be impaired due to age and or inadequate maintenance. When to replace them? It depends on your individual power requirements and your tolerance for power conserving measures. A deep discharge battery has a limited number of charge/discharge cycles and their capacity to hold power will diminish with use or time.
Gunni
Mar 16, 2010
5,937
Encourage you to read and re-read Maine Sail's battery guidance because it is a good mix of technical detail and real-world experience. Pretty sure he's blowed a lot of stuff up, which makes him an expert in my book. So when he says do or don't do something, while I may not understand why, I know he has been there and done that.
Batteries are at the core of the sailing experience- comfort and safety. Extremely important ships system. But they are part of a system - charger, house load, instrument monitoring. Until you are ready to go all-in and implement a systems approach you probably are better off doing what Head Sail says and just abuse what you have while learning, designing and installing your system. Your old batteries can be the last component you replace.
Not sure that you can equalize a Victron AGM, but that may be one option to revitalize your batteries if Victron approves and tells you how. I would pull the batteries out, just in case.
114
Hey guys, thanks for all your replies, Im going to try Main Sails 2 hour test to start, this should give me rough idea, I will report back after.
