A couple of thoughts on repacking a stuffing box. While I also believe in the "if it ain't broke, don't fix it" rule, I also believe in the "Law of Unintended Consequences." Some boaters continue to "adjust," i.e., tighten the compression nut on the gland long after they should have repacked it. If the packing material in your gland is old and dried out, it is possible it will score your shaft making it impossible to control the drip rate when the packing is replaced. A new shaft may then be in your future. And while replacing the packing is "usually" done fairly quickly and easily as a DIY job by most owners, unforeseen problems can arise. Chief among these are being confronted with a corroded or really cruddy compression nut or lock nut that refuse to loosen as they have been more or less frozen in place. Sometimes this can be resolved by using PB Blaster or some other penetrating lube on the nuts before trying to loosen them. Another method that reallly works, and contrary to intuition, will not damage your gland or log, is to hit a "flat" on the compression nut with a ball peen hammer, in a counter-clockwise direction, to break the grip of the crud holding it place. Finally, getting all the old packing material out can sometimes be a real chore. On my boat, for example, I only have about 4 inches between the forward side of the compression nut and the trans coupler so getting a packing removal tool into the opened nut is a challenge. I use bent needle nose pliers. So, keep all this "stuff" (pun intended) in mind if you decide to repack the gland yourself.
