When sailing
RossC
Nov 21, 2011
4
Catalina 42mk San Diego
When sailing , what is best to have your transmission set , Forward, neutral or reverse?
RossC
Nov 21, 2011
4
Thanks, I also have always sailed with my trans in reverse but a friend was disagreeing with me so I thought I would ask.
Jan 4, 2013
285
Catalina 270 Rochester, NY
Unless your transmission says keep locked or something like that put the transmission into NEUTRAL and let the prop spin. It has been proven the drag is substantially less with a spinning prop verses a locked prop.
Apr 11, 2012
324
Cataina 400 MK II Santa Cruz
You should check with your transmission manufacturer. Yanmar is very specific, keep in neutral. Hearth says neutral is best, reverse is OK. I don't know about others.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
That's contrary to a Navy study. Depends on a lot of factors. Speed sailing is less important than wearing out a $2,000+ gear!
jviss
Feb 5, 2004
7,089
found here: http://www.nathape.com/res/Logoundanderes/hurth_hb_manualowner.pdf
(I've tried to faithfully transcribe this, including punctuation and bolding).
Rotation of the propeller without load while the boat is sailing, being towed, or anchored in a river, as well as operation of the engine without the engine stopped (for charging the battery), will have no detrimental effects on the gearbox.
Important
When the boat is sailing (engine stopped), the gear lever must be in zero position. Never put the gear in the position corresponding to the direction or travel of the boat.
Locking the propeller shaft by an additional brake is not required; use the gear lever position opposite your direction of travel for this purpose.
Jan 4, 2013
285
"That's contrary to a Navy study. Depends on a lot of factors. Speed sailing is less important than wearing out a $2,000+ gear!"
We are NOT IN THE NAVY! We are small sailboat sailors. Here is a test by Yachting magazine on props.
http://www.flexofold.com/upload_dir/docs/Test_YachtingMonthly_low.pdf
Look at the drag curves for different types of props, including fixed 3 blade and free to rotate.
My Catalina manual says it is perfectly OK to let the prop spin in neutral. As I said earlier, check your manual or transmission label.
jviss
Feb 5, 2004
7,089
No need to be nasty about it. The study I am referring two was conducted to answer that question for the Naval Academy sailing team, on Navy 44's, if I recall correctly.
The conclusion was that 2-blade props produced more drag when allowed to freewheel than when locked.
Yachting Magazine v. MIT and Naval Academy? Gotcha.
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
Agree...any gear but forward...I use neutral.
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
I use reverse cause the noise it makes while spinning (low bearing noise) bothers me while sailing.
