I am about to replace the prop and shaft on our H34. I have had a past problem with a thumping noise that only happens after we have run under power for some time- 1 hr or so. happens when I throttle down then pick back up to ~2000rpm. Only way to get rid of it is to rev up through it, then back down. The shaft is old and when I had it checked a few years ago it was borderline, I have the shaft out, and although I thought the thumping sound was the shaft bumping on the shaft tube, there is no marks on the shaft at that point. The cutlass bearing appears evenly worn.
I am thinking about replacing the motor mounts as one other possible culprit. However the months for the Yanmar 3GMF are $+200 each so I want to be fairly sure I need new ones. How can I tell?
Thanks
Thanks
