Since you asked the question, you must be worried.
Rig a light bulb in the engine compartment.
You're in salt water; water trapped in intake lines won't freeze. Close all thru hull seacocks. If deck scuppers freeze over over night, they will thaw and drain when daytime warm temps return. The boat will retain daytime warmth, sustained by the water temp surrounding it sufficient to keep your fresh water pressure system from freezing, but you may feel better if you drain it of fresh water and put enough POTABLE antifreeze in the system to fill the hot water tank and the system from the fresh water tank outlet thru the pump and all of the faucet outlets.
My boat stays in New Bern NC and this is all the cold weather prep I have had to do, even with temps that drop toward the 15 degree mark overnight.
