I finally got my boat in the water for the first time this year. We got out in some conditions that were a little rough for my experience level, so I thought I should ask this forum a question or two about reefing. We were trying to beat into a breeze blowing at about 14 - 22 knots out on Lake Huron. The boat was mostly heeling at about 15 - 25 degrees, which is a little high for my comfort zone, so we put one reef in the main. We were still heeling plenty, with one gust almost dipping the rail in the water when I was a little too slow to point up. I was a little frustrated to be only going about 3.5 - 4.5 knots, and every time we hit a big wave or two, we immediately dropped 1/2 knot or so in speed. I was hesitant to reduce sail more because I wanted to maintain a reasonable speed, but between the heeling and the waves, the ride was a bit more unsettling than we would like. The next day, the wind was a little lighter (with smaller waves), so we decided to go out for a leisurely sail with a double-reefed main and no jib. We were still able to go upwind at about 3 - 4 knots, with a much more relaxed atmosphere. That made me feel like I should have reduced sail more the previous day.
So my questions: What is a reasonable speed expectation for going upwind on a day like this? For reducing sail area, when do you drop the jib vs. taking a reef in the main? We were using a normal sized jib (not a genoa), and our main has two reefs. Do you normally take in both reefs before dropping the jib, or should the jib be taken down first? (I don't have roller furling.)
