When AI gets boat maintenance advice completely wrong!
Nov 6, 2020
629
Mariner 36 California
Me;
"What maintenance practices are recommended for boat inverters to avoid corrosion?"
AI;
Regularly rinse the inverter and its connections with fresh water after use, especially in saltwater environments, and apply a corrosion-inhibiting spray like Yamashield to external surfaces and electrical connections to create a protective barrier against moisture. Inspect battery terminals for corrosion and clean them with a baking soda solution or a specialized terminal cleaner, then apply dielectric grease to prevent future buildup.
I noticed that there was a reference link to a Yamaha Outboard forum at the bottom of the reply.
Jan 4, 2006
7,870
I think a pressure washer would do a beter job of getting the salt crust off the terminals :facepalm: .
I have come to realize that I will ONLY ask AI for links to a particular part or material of which I am in hot pursuit. I would NEVER ask AI for recommendations on how to perform any method, strategy, or action. Asking the pet dog would produce a more reliable procedure.
That is a pretty spectacular failure. I just tried the same question in a few different versions of Gemini and it gave much more reasonable answers. For example, this result from their “lightest” model:
Preventing corrosion on a marine inverter requires a dual focus: protecting the high-current DC and AC electrical connections from environmental degradation and ensuring the internal electronics and chassis are shielded from moisture, salt-air condensation, and stray electrical currents.
Key maintenance practices for boat inverters include:
1. Environmental & Location Management
  • Control Humidity and Condensation: Inverters should ideally be mounted in a dry, well-ventilated, temperature-controlled space (such as a dedicated electronics locker or dry bulkhead), far away from the bilge, water tank fittings, and engine exhaust paths.
  • Maintain Forced Ventilation Filters: If the inverter uses cooling fans, inspect and clean external dust/debris filters regularly. Restricted airflow forces the unit to run hotter, which breaks down internal component life and accelerates chemical oxidation on circuit boards.
2. High-Current Cable and Terminal Maintenance
  • Inspect DC and AC Terminals Annually: High-amperage DC connections (battery positive and negative leads feeding the inverter) are prime targets for crevice and galvanic corrosion due to heat cycling and high current draw. Check for any green powdery buildup, white crusting, or black discoloration on copper strands.
  • Use Tinned Marine-Grade Wire: Ensure all cables connected to the inverter use tinned copper wire, which dramatically slows down moisture migration under the insulation.
  • Protect Connections with Adhesive-Lined Heat Shrink: Terminals should be crimped securely and sealed with marine-grade, adhesive-lined heat-shrink tubing to lock out ambient moisture and salt air.
  • Apply Corrosion Inhibitors Correctly: Once mechanical and electrical integrity is verified and tight, apply a thin coat of a protective spray (such as a specialized terminal protector or a light film of dielectric grease) over the exterior of the assembled terminal to block moisture. Never use grease as a substitute for a clean, tight metal-to-metal contact.
3. Chassis Grounding and Stray Current Protection
  • Verify DC Negative and Chassis Bonding: Ensure the inverter’s chassis ground terminal is correctly tied to the boat’s primary DC negative / AC safety ground bus in accordance with ABYC standards. A floating or improperly bonded inverter chassis can build up stray electrical potentials, accelerating localized electrolytic or galvanic corrosion.
  • Isolate Dissimilar Metals: When mounting the inverter chassis or attaching grounding lugs to aluminum or stainless surfaces, use compatible fasteners (e.g., 316 stainless steel hardware) and appropriate barriers to prevent galvanic reaction between the chassis footprint and the bulkhead.
4. Internal Board Protection (Conformal Coating)
  • Check Conformal Coating During Servicing: Quality marine inverters feature factory-applied conformal coating (a protective polymer layer) over their internal circuit boards to shield microscopic traces from moisture and salt air. If an inverter must be opened for repair or troubleshooting in a specialized shop, verify that this coating is intact. If flaking or cracking is visible, it should be meticulously touched up with marine-grade circuit board sealant to prevent micro-arcs and trace corrosion.
Any AI is only going to be as good as the sources it’s trained on, sometimes combined with its ability to do web searches and summarize the information it finds. In any case if it doesn’t give a source as a link that reduces its trustworthiness, and if it doesn’t give give a link check there to see if it’s a good source and if it really says what you expect.
On the other hand, I’ve had very good success with Google Notebooks for questions like that. Load up the owners manuals for all your equipment, and then you can ask questions that the AI will answer using just the manuals as the sources.
  • Helpful
Posed the same question to Claude and obtained advice similar to @Davidasailor26's question. Claude did not provide sources when I first asked. After specifically requesting sources it included a number of sources. I didn't check them as several seemed to have good face value, Victron, Practical Sailor, Sailing Magazine, and so forth.
I’ll look for authoritative marine electrical sources (ABYC-aligned guides, boating organizations, and manufacturers) that back up these points.
I found support for most of the advice and corrected a couple of points along the way. Sources are listed at the end.
Supported by the sources
Placement and ventilation
  • Victron’s manual says the inverter should go in a dry, well-ventilated area, as close as possible to the batteries. Victron also says never to mount it directly above the batteries. victronenergyvictronenergy
  • One marine-specific manual says not to install the inverter below or near the waterline, to keep it away from moisture, and to use only non-corrosive marine fasteners. manualsdir
  • Excess heat reduces service life and can reduce output or shut the unit down. Victron also says not to cover or block the ventilation openings. victronenergyvictronenergy
  • Victron’s rated conditions are non-condensing humidity below 95%, which supports keeping condensation away from the unit. victronenergy
Wiring and terminals
  • Dirt or corrosion on terminals can make them hot enough to melt wire insulation. The same source recommends checking tightness with two wrenches, cleaning the surfaces, and adding dielectric grease. battlebornbatteries
  • Corrosion increases electrical resistance, and that source recommends a baking soda and distilled water mix with a wire brush for cleaning. rvtravelrvtravel
  • A Sailing Magazine reader answer suggests sealing terminals with adhesive-lined heat shrink to stop water wicking up the wire, then coating the mating surfaces with dielectric grease. sailingmagazine
  • A boating forum poster notes that grease should go on after the connection is made, since it can block conductivity. That’s anecdotal, but it matches how dielectric grease is generally used. bassresource
Grounding and bonding
  • Improper bonding can cause galvanic corrosion and stray current corrosion. edecoa
  • Shore-power grounding can bring galvanic risk, and a galvanic isolator or isolation transformer can be used to prevent it. Magnum’s manual says the isolator blocks low-voltage corrosion currents while still passing AC fault currents. gpelectricmanualsdir
Inspection and equipment
  • The US Department of Energy recommends recurring preventive maintenance following NFPA 70B: inspect, clean, tighten, and test equipment. That guidance is for solar PV in corrosive environments, but it applies by analogy. energy
  • One marine electrical guide recommends annual electrical inspections of wiring, terminals, and connections for corrosion, chafe, or heat damage. amnautical
  • Standard inverters lack the protection against corrosion, vibration, and temperature changes that marine operation needs. This comes from a marine inverter vendor, so treat it as manufacturer-sourced. edecoa
  • At least one manufacturer warns that incorrect installation on boats can cause corrosion damage, and that a marine electrician should install the inverter. manualslib
Corrections to what I said earlier
  • Tinned copper is recommended, not required. Practical Sailor reports that ABYC does not mandate tinned wire and most production builders still use untinned wire. Tinned wire is also not immune to corrosion, because the cut ends are untinned. Those ends must be sealed. practical-sailorpractical-sailor
  • Match your terminals to your wire. One technical reference warns that bare copper terminals on tinned wire can create a galvanic cell at the connection. Use tinned lugs with tinned wire. industrialmonitordirect
  • Not all dielectric greases perform equally. Practical Sailor’s test found a plain silicone dielectric grease had slightly lower anticorrosion performance because it lacks anti-corrosion additives. Their test compared it with conductive greases. practical-sailor
Not directly sourced
I didn’t find a reliable source for these specific points, so treat them as general practice or my own judgment:
  • Drip loops on cables
  • Small heaters or dehumidifiers in cold, damp lockers
  • Wiping the case with a damp cloth
  • Desiccant packs
  • Specific inspection intervals (“every few months”), apart from the annual inspection above
For your own unit, the manufacturer’s manual is the best reference, and a marine electrician can confirm anything involving ABYC compliance.
Sources:
Just wondering, if you don’t mind “selling out” the guilty party - what provider and model was that? I have my own suspicions on some models more likely to make a mistake like that than others, but I’m curious whether I’m right.
AI is a tool, and you can get a variety of responses (as @Davidasailor26 shares). If we are to understand the strengths and limits of this tool, we will need to test the many ways the tool responds.
I asked an AI tool the same question and generated two differing responses. Both come from the same learning that the AI tool has been given.
First response:
Recommended maintenance for boat inverters focuses on keeping them dry, well-ventilated, properly connected, and protected from salt air, humidity, and condensation—the main drivers of corrosion in marine environments.
Installation Best Practices (Foundation for Corrosion Resistance)
  • Mount the inverter in a dry, well-ventilated location away from bilge water, spray, and battery gases. Do not install it directly above batteries, as even sealed batteries can vent corrosive fumes. Leave clearance (typically at least 10 cm / 4 inches) around the unit for airflow; vertical mounting is often preferred for cooling.
  • Use marine-grade units with conformal-coated circuit boards, corrosion-resistant enclosures, and suitable IP ratings. Standard household inverters lack these protections and fail faster in salt air.
  • Secure with corrosion-resistant hardware and ensure proper grounding/bonding per ABYC standards. For shore-power-connected systems, install a galvanic isolator or (preferably) an isolation transformer to block low-level galvanic currents that accelerate corrosion of underwater metals.
Wiring and Connection Protection
  • Use tinned marine-grade wire and properly crimped, sealed terminals. Seal every connection with adhesive-lined heat-shrink tubing.
  • Apply a thin layer of dielectric grease to terminals, plugs, and fuse holders after cleaning. It blocks moisture and oxygen without impeding conductivity.
  • Keep connections tight (vibration loosens them over time) and elevated above potential water. Use drip loops and avoid routing through wet areas.
Regular Inspection and Cleaning
  • Inspect the inverter, terminals, cables, cooling fins, and vents at least seasonally (or more often in saltwater use). Look for white/green deposits, looseness, moisture, or dust buildup.
  • Clean terminals with electrical contact cleaner (or a baking-soda solution for battery-related corrosion), dry thoroughly, then reapply dielectric grease or a marine corrosion-inhibitor spray. Never spray water directly onto electrical components.
  • After saltwater exposure, gently rinse surrounding areas (engine compartments, enclosures) with fresh water and allow everything to dry. Maintain ventilation to minimize condensation.
  • Check cooling fans and fins for debris; restricted airflow raises temperatures and can worsen condensation issues.
Environmental Controls
  • Prioritize good airflow and reduce humidity where possible. In harsh coastal conditions, some owners use dehumidifiers or vapor-phase corrosion inhibitors (VpCI emitters) in enclosures.
  • Even quality marine inverters (e.g., Victron MultiPlus) can develop internal PCB corrosion over years in extreme salt-air environments if not protected by location and ventilation.
System-Level Measures
Maintain the boat’s overall corrosion protection: sacrificial anodes (replace at ~50% depletion), proper bonding of underwater metals, and a functioning galvanic isolator or isolation transformer. Faulty shore-power grounding or stray currents can indirectly stress electrical systems including inverters.
Manufacturer manuals (Victron and similar brands) emphasize dry/ventilated installation, annual connection checks, and avoidance of humidity/dust as the core maintenance. Always follow the specific unit’s manual and ABYC guidelines. For complex issues (shore power, bonding, or internal corrosion), consult a marine electrician. These practices significantly extend inverter life in the marine environment.
Second Response:
The Facts?
Boat inverters (and inverter/chargers) fail from corrosion primarily due to salt-laden humid air, condensation, and moisture intrusion rather than direct submersion. Manufacturers (Victron MultiPlus/MultiPlus-II series and equivalents) specify installation in a dry, well-ventilated compartment with free air space around the unit (typically ≥10 cm), never directly above batteries because of corrosive gases, and with vents kept clear. Marine-grade units use conformal-coated PCBs and corrosion-resistant enclosures; household units lack these and corrode faster.
Practical practices that reduce corrosion:
  • Use tinned marine-grade cable and adhesive-lined heat-shrink or sealed connectors on all DC and AC terminations.
  • Apply dielectric grease to terminals, plugs, and fuse holders after cleaning.
  • Inspect connections, terminals, cooling fins, and fans at least annually (more often in saltwater service); clean oxidation with electrical contact cleaner, dry thoroughly, and re-protect.
  • Maintain airflow; restricted cooling raises internal temperatures and promotes condensation cycles.
  • For shore-power systems, install a galvanic isolator or (better) an isolation transformer so the boat’s ground is not directly bonded to the marina ground—prevents low-level galvanic currents that accelerate metal loss.
  • After saltwater exposure, rinse surrounding surfaces with fresh water (do not spray the inverter itself) and allow drying. Keep the area free of standing water and salt residue.
  • Follow the unit’s manual: most state “check connections yearly, avoid humidity/dust, do not operate in wet environments.”
These steps address the dominant failure modes observed in coastal and marine installations.
What assumptions are you making?
  • That the inverter is a standard marine or dual-purpose unit (Victron-style or similar) rather than a fully sealed, high-IP industrial unit or a non-marine household model.
  • That the boat has or will have proper DC cabling, bonding, and (if shore-powered) galvanic isolation already considered.
  • That “avoid corrosion” means both external terminal/enclosure corrosion and internal PCB/component corrosion from salt air.
  • That routine owner-level maintenance is acceptable and that professional ABYC-compliant installation has already occurred.
  • That the primary threats are salt humidity and condensation rather than continuous submersion or chemical exposure.
What is uncertain?
  • Exact service-life extension numbers for any specific practice (manufacturer data on conformal coating longevity in continuous salt fog is limited and environment-specific).
  • Whether a given unit’s factory conformal coating is complete or partial; some coastal failures still occur after many years even on “marine” inverters.
  • Optimal frequency of inspection in different climates (constant tropical humidity vs. seasonal temperate use).
  • Effectiveness of aftermarket vapor-phase corrosion inhibitors or extra conformal coating applied by owners (can help but may affect warranty or heat transfer).
  • Long-term performance of dielectric grease or sprays under continuous vibration plus high humidity—widely recommended but not rigorously quantified for inverters.
What are you leaving out?
  • Detailed model-specific torque values, cable sizing, or fuse requirements (follow the manual and ABYC).
  • Full bonding/grounding system design, anode selection/sizing, and stray-current diagnosis procedures.
  • Warranty implications of opening the case, applying extra coatings, or modifying ventilation.
  • Comparison of specific brands beyond general marine vs. non-marine distinction.
  • Electrical safety procedures for working on live AC/DC systems or shore-power isolation.
  • Cost-benefit analysis of isolation transformers versus galvanic isolators.
  • Advanced monitoring (e.g., continuous humidity logging or remote VRM-style alerts for early failure signs).
Likes: BAD ORCA
One of the things that makes AI sound so “human” is that it mixes some randomness into its responses. It picks each “token” (part of a word) based on statistical modeling of all the tokens that came before. Sometimes, especially when two tokens that could be chosen are almost equivalently likely, the model will pick the slightly less likely one to avoid giving a mechanical response. Once a different token is chosen it can affect the whole rest of the dialog, thus the two different responses from one query.
This token prediction is also susceptible to getting sidetracked by other parts of the conversation. If the OP asked that original question in some conversation that had once contained another statement like “I dunked some electronics in salt water, what do I do now”, then the earlier tokens could get mixed in with the latest question and bias the response. For that reason it’s usually best to start a new conversation for each new question, unless it’s related to facts in some existing thread. Starting a new conversation also prevents “context rot”, where the model gets overwhelmed by the number of tokens it needs to track, and starts to forget ones that could be essential to giving a good answer.
Different providers could be tuned with different “temperatures” to make these changes more or less likely. A higher temperature might be better for creative writing but worse for technical documentation.
629
It was chatGPT 6.0. It was the 'free' version embedded in DuckDuckGo's search bar. There is an AI option next to the search. To be fair to chatGPT, the response I got above was a 'follow up' elaboration answer. In the side bar on the right there were elabortions, or 2nd, 3rd opinions. It was one of those that i clicked on. The first general question was slightly different and it led to one of the links above that advertised something like 'proper inverter maintenance'. when i clicked on it i got that response with some strange reference links. I generally use chatGPT 6 and the replies have been mostly good on first response advice up to a point. I usually always have it in 'deep think' mode though.
Nov 6, 2020
629
Yeah I noticed that as well.
Nov 6, 2020
629
Thats interesting. Yeah the response was after a short chain of related questions. It was actually a 'recommended' link related to the original questions. Somehow it chose some reference links to websites that were not at all related to inverters and got confused. It ended up substituting outboard motor maintenance with inverter maintenance.
