Good Vibrations
Good Vibrations (fun Beach Boys song)Are these new vibrations that you are experiencing, or have they always been there and you are just now asking questions about them?If they have always been there, what kind of prop do you have? Two blade, three blade, etc.? From what I hear, two bladed prop - while less of a drag on sailing performance, is more prone to vibration than three blades.If the vibrations came about recently, then look for something that changed on the boat - did you tag something with the prop - causing it to become out of balance? Did you make adjustments to the rig tensions or engine alignment?If maybe they came about slowly and you are just now noticing, is there growth on the prop (barnacles?) What kind of zinc do you have? prop cone, shaft, etc. What is it's condition? Was it recently changed?Just throwing out suggestions to help pinpoint what might have changed to cause (not so) Good Vibrations.Fun, Fun, Fun ('till daddy takes the tiller away).Tim BroganApril IV C350 #68Seattle
