Hi Jim, can you describe your situation in...
more detail? Does the catch happen only when the autopilot is engaged, or in standby, too? What about when it is turned off, does it still catch? What does the catch feel like, does it stop the steering movement until you turn it past the catch or is it a hesitation?Disconnect the autopilot system from the steering system and feel whether the catch is in the steering or the autopilot drive. If it is in the steering system, I would visually trace the entire steering cable path from the helm to the quadrant. It could be an electrical wire in the helm tube interfering with the chain drive portion of your steering system. One of the cables could have jumped off one of the sheaves or the rudder post could be binding.If the steering cable path looks and feels clear, then disconnect the cables from the quadrant and turn the quadrant by hand to feel whether the catch is in the post bearing.It could also be the autopilot drive system binding either because a plastic wheel inside the drive is worn or broken or the belt is worn or binding. Lots of possibilities.Terry
