Any tips on removal? I’m leaving the gear puller on overnight while tensioned. So far I’m just bending the puller jaws. Will heat discolor it?
Good to hear. I think O'Reilly's is where i borrowed mine.Went to the boat today and the puller was on the cockpit sole. I put a blanket down if it popped so no gel coat chips. Puller popped but the wheel did not. Took Richard’s advise (thanks) and O’Reillys Auto had a loaner program for tools. 2ton puller with three jaws that didn’t bend. I had to pull the wheel off it’s whole travel which is strange. 6-7 yrs ago, I had the wheel off and lubed it wheel bearing grease when it went back on. This time I used white lithium grease.
