Yes, It is Normal
To answer question #1, yes, it is normal. All boats with a symetrical rudder and an in-line power trane and prop will have a pull to one side under power, and it's not limited to boats. If you have a front-wheel drive car you can feel a pull on the steering wheel and on a plane, same thing, there will be a pull. Most small planes, however, have a trim tab which the pilot can adjust according to the situation, such as climb or level cruise.Some (all?) C&C boats have their engine and prop shaft skewed several degrees from centerline to help combat the torque.Question #2: Can you do anything about it? Realistically, I'd say no. I've seen people attach a trim tab to the rudder but this would add drag and be more problem than it's worth. Plan B is to switch to a C&C.
