Wheel lock
Feb 3, 2014
94
Hunter 44 aft cockpit Miami, FL
Every time I sail I have to screw down my folding wheel locks over and over. I am speaking of the large black oval-shaped spoke-locks that allow you to collapse the wheel. Is there a fix for this?
7,507
Alden 50 Sarasota, Florida
Yes. There are kits readily available if it a contemporary make consisting of the friction bars similar to drum brakes on a car. Check your local chandlery or on-line marine sources.
Aug 26, 2007
274
Hunter 41DS Ventura, California
I think the kits that Don is referring to are for the lock that keeps the wheel from turning. I don't believe that there is any product available to eliminate the spoke screws.
You could jury rig a system using close fitting tubing (PVC or whatever) to slide over the spoke joint but unless it was a tight fit there would need to be some way to secure it so the wheel wouldn't accidently fold. This would most likely occur during a stiff wind jibe, tight space docking or close maneuvering in a crowded marina.
May 24, 2004
7,190
CC 30 South Florida
The more I hear about folding wheels the better I feel about my decision to just install a smaller diameter one.
Oct 12, 2014
42
Hunter 36 Port Ludlow
I have a folding wheel and love it. Out of the way when I need it to be...there when I need it. Worth the 17.2 seconds it takes to secure it.
Feb 3, 2014
94
Do you folder lovers have to continually tighten the locks as I do while sailing?
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
have you checked with the wheel manufacturer about that problem they may have some good insight for you
Feb 3, 2014
94
I did write to Edson. They replied (promptly) that they wanted a photo of what I was referring to. I will do that on Saturday.
