Looks Like Overheating Takes The Prize
I have a 3GMF and the only problem I have had is overheating on two occasions. Both times were from weeds that were restricting the flow in the raw water strainer.When we are cruising, I try to check the engine at least once an hour for leaks and each time I put my hand on the mixing elbow. Even at 3000 rpm it will only be warm. If it is uncomfortable to the touch, I slowly idle down over a few minutes to allow the engine to cool slowly and then shut it down and clean the strainer. Upon start up it is immediately cool and we are on our way.I also purchased a new elbow this spring, but after inspecting the old one I decided that would be a next-winter project. I pulled off the exhaust hose and using a mirror and a light, inspected the elbow. It had some build up but the passages were not restricted so I decided to leave well enough alone.A couple of other suggestions. Be sure to change the small Yanmar fuel filter and if you do not have one, install a water seperator/filter before the fuel pump. Secondly, install new fan belts to insure that the engine water pumps are turning. If you have a freshwater cooled engine, the impeller in the raw water pump needs to be inspected and replace if you see any cracking. (Replace it anyway, they don't cost that much and it is great insurance.)Good Luck!
