Hunter 212
The Hunter 212 was designed to be a fast and stable large daysailor with a small cabin. Interior is of course spartan. I never ordered the boat with the galley unit as I felt it was too much and bulky. You can get a portable butane stove and the little water you will use can be carried on board. Never would I drink from the water source in the galley unit.As for the cushions, you can opt for the interior cloth cushions. As for the rudder breaking, I have yet had that to happen with the ones I have placed out there. I wonder what the circumstances were when it broke would tell me better. As for the cracks mentioned, there was some problem with the raw material as the manufacturer of the raw materials let some get by to Hunter Composites accendentaly. It is easy to fix but in the worst case, the boats were replaced. Not many sailboat companies would do this but Hunter did. Have not had any trouble since then. All in all, the 212 is a nice boat to consider as a large daysailor with a small cabin. If your intent is to stay on board for long periord of times, then I would suggest considering the 240.I hope that helps you Dave and should you have any other questions, please put a new post to Crazy Dave-212. Thanks and good luck.Crazy Dave Condon
