It looks like about five years for a macerator pump. I noticed mine was taking a bit long to empty, so I figured it needed servicing. It was five years old almost to the day, a Jabsco 74001-1855. Well after battling the access, I removed it and started disassembly. The first thing I noticed was the cutter blade was fouled by hair or other fiber. Probably still worked, but without the designed efficiency. Then I started to remove the four mounting cap bolts that attach to the brass retaining studs. Well, three of the brass studs just fell out. The studs were broken. The last one I removed. I could see there had been some leakage at the gasketed impeller housing seam, no surprise with only one stud holding it.
I found the impeller was missing a blade. So, I pulled everything apart, cleaned it up, got new zinc-coated steel studs, greased them up to resist corrosion for a while and started reassembly since I had a spare impeller and gasket set. Everything went well until I noticed two of the old studs were embedded in the brass threaded female insert in the impeller housing. I drilled those out and just through bolted them to the base.
I then field tested it by filling up the (empty & clean) holding tank with fresh water and turning on the macerator. I was dejected to discover it wasn't pumping! Then I remembered I hadn't replaced the pump-out cap. All went well after I did.
Anyhow, it is annoying to find the brass studs were broken, since that is exactly what I found five years ago when I replaced it last. Twice is more than coincidence. Any of the rest of you find this? i wonder if Johnson Pumps or Sureflo pumps are the same? I am going to pull up their views and check.
