Hi,
Could anyone help?
While replacing the thermostat, I broke one of the two bolts securing the thermostat housing at a level of 12 ft-pounds. Then the lower housing cracked at a torque of less than 15 ft-lbs. of the bolt on the right side, when facing aft. I was very carefull stepping in less than 5 lb increments with a torque wrench. My plan will be to torque to 15 ft-lbs, in 2 lbs increments.
Engine: 1989 Universal M-25XP
As I recall, the manual says 35 to 42 or so ft-lbs.
Thanks,
Chris
Could anyone help?
Thanks,
Chris
