Photos
Lonnie, I don't have the camera till Monday, I'll post some shots then. The plank under the bow roller is Mahogany. I think the Mac looks better with the plank and roller. I don't think the weight makes any difference. I have seen 35 gallon water tanks built into the V-berth, this weight is negligible and maybe offsets the outboard hanging off the other end.The forward wall of your v-berth can be removed to open up the space where your bow eye hardware and your stem fitting lives. You can saw out the forward wall of the v-berth, it is quite thin. This area makes a great place for the rode. Some have done this and made a screen for the rode to sit on and drain. I have seen one boat with a nice cabinet door that allows access, but looks nice. I have a deck pipe installed above that I feed the rode down. The deck pipe holds the 10 feet of chain when the door is closed on the deck pipe. It does require cutting a hole to mount the deck pipe. I made a large backing plate to mount under the deck to bolt to the plank above, making a sandwich to rigidify the deck there.I wish I had bought a bigger size anchor. The set up on my boat will accept a larger anchor, so maybe later. I have some firsthand experience with this type of anchor in high winds. It hooks and holds. I had a danforth type, for my primary, and it was hard to set, and I did not trust its holding power. I have slept on my boat at anchor, I ran the anchor line out the end of the roller and captured it with the anchor holding pin that goes through the anchor shank. If it were necessay, I could lead the rode to the bow eye for the best angle.When I first got this setup installed. I took it to the local lake and set the anchor by pulling it against the motor while going upwind. It set and opposed the motors force. Then I shut off the motor and allowed the boat to coast past the place the anchor was set. As the end of the 200 foot rode was reached, the anchor was pulled 180 degrees from the angle it was just set with the motor. The anchor reset itself with little sliding. This was on a mud and sand bottom. I wanted this type of anchor. There is no way to safely store this kind of anchor without a bow roller. Works great. John S Boise
