Whats the best way to drill into pedestal guards?
weinie
Sep 6, 2010
1,297
I will be installing an X5 auto pilot and need to drill 2 new holes in the guard to run the wires for the control head and steering motor.
I fear that the drill bit will walk all over the stainless steel guard.
Anyone have any hints?
Ross
Jun 15, 2004
14,693
mark the locations with a sharp center punch.
Oct 24, 2011
258
Lancer 28 Grand Lake
when i drill anything that the drill is likely to slipp on, i put duct tape on it, in the form of a cross, then drill right through the center of the cross, the duct tape, stops the drill from slipping. Stainless is not the easiest thing to work, so make sure you use a new and unused drill for it.
BobT
Sep 29, 2008
239
Gulfstar 37 North East River, Chesapeake Bay
And if your final diameter is 1/4" or larger, drill a starter hole.
With some drills it's hard to keep the speed slow enough for metal work.
Dec 2, 1999
15,184
If you can easily remove the guard, remove it and put it in a drill press.
Jun 3, 2004
18
Hunter 410 Boston Shipyard
Buy an electrical ground clamp that is intended to clamp to a water pipe. Calmp the ground to the round pipe. Remove the screw that usually holds the ground wire wire and use the hole as a drill guide.
Oday 35 and Mariner 2+2 Alexandria, VA
I have had very good luck with a dremel diamond tip taper to make a starter divot. If I need a large hole, I will etch the starting point then use a new drill bit to make the hole. I then use the dremel taper to smooth the edges. Or if it is a small hole just use the dremel bit to bore all the way. Go slow keeping steady pressure but don't force the bit and you will have no problem
May 24, 2004
7,230
CC 30 South Florida
Place some masking tape on the tube and mark the location with pen or pencil. Take a sharp center punch and press it against the mark insuring its axis is perpendicular to the surface. Then strike a solid single blow with a ballpin hammer. You should now have a slight indentation at the place you want to drill. By applying prsessure with the drill the drill bit will remain in the indentation until it bites and not wonder around. Keep the tape in place for protection until the hole is done.
Jul 25, 2005
43
NULL NULL Boston
It will be much easier than you expect.
Use a center punch to locate the hole and provide a stable positon for the drill bit.
Important: Use a COLBALT drill bit, with a hand drill Slowwww speed.
Bob D
Boston
Beneteau 323 Annapolis MD
I placed a couple dozen snaps in/on the stern rail, so tried a number of options. I used painting mask tape (blue, green) in several layers. That holds the drill bit enough to start a dimple.
As in post 6, Sailrite sells a tool to clamp to a rail to make a starter hole. You might make the same tool with one of those clamp-on taps, like used for waterlines to the ice maker.
JohnS
177
Islander (Wayfarer/McGlasson) 32 St Georges Harbor
Haven't tried the tape method. I know a center punch will work. They're cheap, and everyone needs more tools, right? Google "automatic center punch" for a handy solution.
That might work if the guard is well-bolted in (sturdy) and you'd hammer athwartships, but I'd hesitate to do it in a fore-and-aft direction. Maybe get the mate to lean on the guard?
derfus
Oct 26, 2009
72
Oday Oday 28, Mac-25 Presque Isle Marina, Erie, PA
Hi, When I installed the X5 on my boat I had to remove the guard and drill through the deck mountiing plate so the wires would pass through.
JohnS
177
That's where the automatic punch comes in handy. No hammer. Just hold the tip in place with one hand, and push. It may take a few strokes to get a good mark on stainless, but it should be good enough to start a small drill bit.
