What zinc do I need on my max prop?
3
beneteau M445 Sausalito
I'm a new owner of a 1993 Beneteau M445. I need to get some spare max prop zincs, but I've no idea what size I need....63mm, 70mm or 83mm. I looked through the literature for my boat, but didn't find that specification. Does anyone know which size I need?
Jan 25, 2013
22
tartan 3700 northport NY
Max prop zincs are sized to fit the hub of the prop. A 70 mm zinc fits a 70mm diameter hub.
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
What is the prop shaft diameter?
Yes, but the hub size is determined by the prop shaft diameter. If he doesn't have the hub size, we can figure it out from that.
7,390
Alden 50 Sarasota, Florida
A reasonable assumption is that KPSAILS doesn't know what size Maxprop he has. It isn't standard equipment on a Beneteau. Given the size boat he has, it likely requires either a 70 mm or 83 mm anode.
Feb 26, 2011
1,440
If in doubt, Contact Max Prop distributor, PYI in Seattle (425) 355-3669
