What type sole/floor
115
Pearson 323 Bayfield
What kind of sole/floor materials are used in boats? All I've ever seen is teak and holly for the sole. Our boat has only the fiberglass liner, but looking at some pics of others of the same make (Pearson 323) it appears there may have been teak and holly originally.
Does anyone have experience with wood other than teak and holly?
Why is teak and holly traditional?
Does the veneer teak and holly wear through in the high traffic spots?
Any other suggestions for a comfortable non skid sole for the boat?
Thanks
Geoff
Jan 10, 2011
331
Macgregor 25 675 Lake Lanier
I have been thinking about putting down some of the soft vinyl flooring and stick it down with spots of silicon.
Any thoughts?
I just have the liner right now.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
New Flooring
I need to replace the floor in mine, which was origionally teak and holly. Not being a traditionalist, pretty frugal, and somewhat lazy, I'm going to install a solid vinyl that is in a bamboo pattern. Besides the other reasons given, I really like the look of it, and it is much lighter in color than the teak and holly, which will brighten up the inside. If interested there are several patterns available in this. Comes in a plank, which glues together with peel off strips. Guaranteed to be water proof. Trade name is Allure, and is available at Home Depot.
Ross
Jun 15, 2004
14,693
I have black walnut as the cabin sole. Silicone is not a good adhesive.
zeehag
Mar 26, 2009
3,198
mine is teak and holly not veneer. i love it and cherish every ding-- gives it character....
chp
Sep 13, 2010
431
Hunter 280 hamilton
Problem I was told about using the vinyl flooring is not to use it if temp goes below freezing. The vinyl tends to shrink too much. I was going to use the Allure and the Home Depot guy said the glue joints will pull apart. Going to try and use bamboo solid wood.
Jun 6, 2006
6,990
At $200 a 4x8 sheet I made my own. 3/4" burch (picked through to find the right grain patterns) plywood with "gunstock" stain for the teak and popular for the holly. 1/4 router the plywood for the popular, stain then glue in the popular and plane down till flat. Ended up being $60 a sheet and only took a few hours to fabricate
Oct 26, 2005
2,057
- - Satellite Beach, FL.
Please post pics!
Have you found the solid bamboo for this? Sounds very cool.
Ross
Jun 15, 2004
14,693
What ever you plan to use give it a boiling water test. Some laminated products will come apart in just a few minutes when subjected to boiling water and will come apart if just soaked in cold water for a day or two.
Nov 9, 2008
115
Thanks
Good ideas here. So far I like Bill's the best. I'm inherently lazy but enjoy woodworking. It drops below zero here (Superior Wisconsin.) so I guess vinyl is out. I also wonder about using white oak. It's somewhat rot resistant. Expansion/contraction will be a problem if I don't use plywood although I suspect a loose fitting pattern could be designed. That could be fine as long as I don't capsize. If I do capsize I'm not sure if I'll be around to worry about the floor. If I do use plywood I'll do Ross's test first.
Geoff
Ross
Jun 15, 2004
14,693
Re: Thanks
There is a pretty good list of durable, stable , hardwoods that take a good finish. Walnut, cherry, w.oak, sassafras are at the top of the list, locust is excellant but the devil to work, much harder than teak. All heart red pine with vertical grain is good and also pretty.
