What type ports
cjfj
Oct 16, 2010
83
hunter H34 Mayo, MD
I have a couple of broken cam mounts on the opening ports I have a temp fix for it now but will be planning on replacing them in the near future. In researching the stock here on SBO I see both Gray and Beckson offering almost the same product right down to the item numbers. Anyone know if theres a differance? are these the same product?
Boat is a Hunter H34 '83
Jul 28, 2013
126
Hunter 34 Holland, Mi
I believe the Gray ports will be a direct replacement. I am installing Beckson ports in my H34 and it requires some cutting. The drains are in different locations. The benefit to the Becksons is that the window is flat so it doesn't retain water like the factory port does. I hope this helps.
Phil Herring
Alien
Mar 25, 1997
4,923
- - Bainbridge Island
Check the frame on the inside of the boat, it should have either Gray Enterprises or Beckson embossed in it. It's important to know because the parts are not interchangeable, even though the ports looks similar.
