What type of wire????
Mark
Is the rigging on a 260. 302 1 X 19 ? "OR" Is the rigging on a 260. 316 1 X 19 ?
Mar 21, 2004
2,175
Hunter 356 Cobb Island, MD
Mark, See if this helps.
http://www.ayesail.net/sailing/Hunter/ManualH260/Page47A.htm Jim
F
Frank Ladd
Likely 304 or 316
If it is 304 a magnet will stick to it a little. 316 does not attract a magnet at all. If you have to replace it for salt water use, I'd use 316. it is harder to find but doesn't cost that much more. Almost all of the rigging fittings will be 316.
Mark
This is very important
For each of these have different breaking strains.
Aug 11, 2006
1,446
Hunter H260 Traverse City
H260 Wire
Hunter uses Hackensack 316 Stainless Steel 1/8"/3.2mm and 5/32/4mm stainless steel cable on the H260. Hunter provided me with a spec sheet that says the nominal breaking strength is 1780lbs and 2800lbs respectively. They recommend rigging be set at 20 percent of nominal breaking strength.
Ray Bowles
Mark, Please contact Ray
Mark, I haven't been able to find you on the site e-mail. I am on the Catalina site. E-mail your address and I get back. Ray
