The best way to bottom paint a C22 on the trailer is to get 2 10' long 2x6 boards and cut them into 8" to 12" pads. Than get a 10' 4x4 Cut it 1' longer than the widest part of the trailer and place it across the top of the trailer frame right in front of the rear bunk supports. Place a small (2 ton) hydraulic bottle jack on the 4x4 just inside of the bunk board on one side, make sure the cylinder is down as far as it will go and the screw is down all the way also. Sit one of the 2x6 pads on top of the jack and measure the distance to the hull of the boat next to the inside of the bunk board directly above the jack. Cut the leftover piece of 4x4 1/2" to 1" less than that measurement. Remove the 2x6 and place the 4x4 on end on top of the jack and place the 2x6 pad on top between the hull and the 4x4 and screw out the extension on the top of the jack cylinder to snug everything up to the hull. now slowly jack up the boat placing a 2x6 pad between the bunk board and the hull as soon as there is enough room, continue jacking and blocking until you have 4 pads in place giving you 6" of space between the hull and the bunk boards. Move jack setup to other side and repeat. If you block as soon as there is room, the most the boat can drop is 1.5" and will usually not do any damage, if the jack or 4x4 kick out, if you wait until it is jacked all the way up damage could be extensive. You can do this from the center instead next to the bunk boards and block both sides as you go but this setup is not as stable. Once both sides are blocked up at least 6" at the rear than move the 4x4 and jack up next to the front bunk board supports front or back side of support works, this time jack from center as hull is narrower and bunk boards are closer together. You may need to trim the 4x4 or cut another piece to fit the front and jack and block until you have 4 2x6 pads in place on both sides. Now you can prep and paint the bottom, once the paint dries jack the boat up again from each of the three points and move the blocking to expose the unpainted areas and set it back down on the relocated blocks and prep and pant the exposed patches. when the patches are dry reverse the process and sit the boat back down on the bunk boards, starting in the front. This method also works well to service and remove the keel, but I use 6 2x6 blocks at each point for keel removal.
