The Bahamas are pretty flat and therefore exposed. The good "hurricane holes" will fill up fast and there still is no guarantee. Someone mentioned a "lee shore". You don't want to be there. You want to be in the lee of an island (which is often referred to as the windward shore - from you). If you know way ahead of time that a tropical depression is heading your way and will soon become a hurricane, then you might have enough time to get away from it, but sailboats are slow and storms are fast. You need a big advance notice. If you can make it to Florida and get up some river and away from the ocean, that is a good thing. But, remember, others will be heading there too and they will fill up fast. If you can get into a marina, then tie up your boat with a lot of dock lines and use big ones. A Hunter 28.5 is not considered an offshore classified boat, so you are even more vulnerable. With a hurricane there is a big surge. Often people think there is a big flood, well sometimes the water runs out of the marina too. But, lots of lines to keep you in place so that your boat does not hit the dock, which is one way how docks break apart.
It usually is recommended that you don't sail Florida or the Bahamas until February at the earliest, March is better - April better yet. Not just for Hurricanes, but also for the Northerlies that come unexpectedly out of the north in those regions. Usually they start going away in February, but not always. That's my 2 cents.
