What thread sealer?
Feb 6, 2013
437
Hunter 31 Deale, MD
I'm re-sealing the engine cooling intake thru-hull. What should I use to seal the threads when I install the valve on the thru-hull? Teflon tape, plumber's putty, 5200?
Thanks.
Feb 6, 1998
11,722
Thanks.
I use Herculese/Oatey Real-Tuff available at any Home Depot.
Just be aware that an NPT valve to an NPS thru-hull fitting is a thread mis-match...
Aug 13, 2012
533
Catalina 270 Ottawa
How about sealing the Marelon threads (between a through-hull and the valve)? The through-hull part is solid (good seal and good backing plate). The issue is the seal between the threads (and they do match).
Blitz
Jul 10, 2007
715
Seidelmann 34 Atlantic Highlands, NJ
I clarified the sealant for Marelon with Art Bandy of Forespar a few months ago - he indicates to "Use pipe dope or Teflon tape on all threads."
I prefer the thicker Teflon tape available at most Hardware stores, MaineSail refers to this in a previous thread.
Aug 13, 2012
533
Catalina 270 Ottawa
it seems that the consensus is on Teflon tape. this is what i will use.
thanks for suggestions
Jun 4, 2015
18
Pearson Electra Central Pa
Been a water & sewage system engineer for twenty years. Just completed sophisticated regional septic pumping system and found a few things. 1.) To pass the plumbing union local's test, you must use both pipe dope and teflon tape in your threaded joint test. 2.) There is a new, grey-colored Teflon tape, created for stainless steel threads - some models with included nickel particles to permit transmission of eddy/ripple-current (similar to dielectric couplings in steel/copper networks.) You can use this thicker tape in all threaded applications 3.) We were pressure-testing to 120 PSIG, holding a buried 4" plastic pipe over 300 feet long to less than half a pint of leakage in an hour. We discovered the Chinese-manufactured 1/2 inch ball valves in the test rig failed with virtually undetectable cracks in their housings (tests failed daily for three weeks before cracks were found) which leaked in a very fine spray, seen only as rainbow in direct sunlight. Replaced with old-fashion bonnet in-line valves and each section passed first time. Do not skimp on valve costs - especially below the waterline. I intend to not use ball valves in the Electra.
