What size outboard shaft for H23 ?
logic2
Feb 4, 2008
2
Hunter 23 denison, texas
Hello, I'm looking to buy an outboard motor (t least 6HP or larger 4 stroke) for my H23 and would like to know what size shaft I should use. Any requirements / suggestions ? BTW...I'm on a large lake with some medium sized waves. Thanks Mike
Oct 3, 2006
1,039
Hunter 29.5 Delaware city
Hey Mike
Do you still have the original bracket? Because you'll want a new one of them too, so you can lift the motor out of the water. As for the motor shaft - longer is better. 25 is ok, 30 would be better. you've got a relatively light boat with with the weight concetrated in the middle, and a flat bottom..she pitches with the wave action. If you want your prop and water intake to be in the water, get an extra long shaft.
logic2
Feb 4, 2008
2
Thanks
I do still have the original bracket for lifting the motor out of the water when under sail. I found a few motors with a 25" shaft and it looks like that's the one I'll go with. Thanks for your advice. Mike
Dec 1, 2005
87
Hunter 23 Pennsville
Yeah you'll wanna replace that factory mount eventually..
and 6 hp should be plenty. My motor's not a long shaft, but I don't really have trouble keeping the prop down, it takes a good swell. When its time to replace it though, I'll probably get one.
