My daysailer mooring
Len, I don't know the Bass River, so I don't know the conditions you'll be moored in, but my Daysailer's mooring is in Casco Bay up here in Maine. It can get pretty exposed when the wind comes from either the NE or SW (which, of course is the prevailing). It not uncommon to get three foot waves in the anchorage. I used a 150# mushroom on 3/8 chain with a float, and I used 1/2 three strand nylon as the mooring pennant. I spliced a snap shackle on the end, and attached it to the bow eye so that the load was more horizontal. You could probably get away with a 100# mushroom, but I had the 150 so I used it.Your boat has low number, which probably means its as DS1. Is that right? If so there are two more thoughts. 1. The boat is not self bailing, which means if you are going to get really heavy stuff, take it home. Once you play with it enough you will be able to rig and derig it inside a half hour, so its usually not that big a deal. If its even remotely possible you are going to get waves more than three or four feet high (rollers are ok, I mean steep ones that could break over the bow and put water in the cockpit) or more than four or five inches of rain, take the boat home. 2. There is a lot of debate over whether the centerboard should be left up or down on the mooring. My take on it is that it ought to be down. I installed a bungie that would hold it in the down position even in the rough stuff but still give some shock absorbtion. I like the board down because it will keep the boat bow to the waves, even if the wind veers. You only have a few inches of free board, so you don't have whitecaps breaking into the boat.This shouldn't scare you off. Daysailers ride moorings all the time. There are at least five of them in the anchorage where mine is.Enjoy.Justin - O'day Owners' Web
