I own a Daysailor 1, 17 footer. I'm thinking of purchasing an outboard.
I'm not aware of any documentation available that would indicate the proper size limit, in hp for a boat of that length. Is there a formula? I was thinking of a 6hp, 20" - 25" long shaft. I understand the weight of the engine is a factor to considefor if it is to heavy the nose comes out of the water.. This engine ways in at 55 llbs. Add 3 gals of gas to that and its looking like 85 +- lbs back there.
3/4/5 hp engines/motors are about 41 lbs and the only additional weight fuel wise is about a quart of gas which is in a built in tank on the motor. That would be a solution but would limit my day, if sailing conditions were to change. Not an option I would consider unless it would be the only option.
Thanks
Okial
Thanks
Okial
