Sailing vs. Bare Poles
Based on the current data, the Jordan Series Drogue appears to be the most optimum form of sea anchor currently available. From a sail maker's web site that sells the Jordan Series Drogue:"By Don Jordan, inventor, retired aeronautical engineerThe series drogue was developed to perform two separate functions:1. To prevent the capsize of monohull and multihull sailboats in the event of a large breaking wave strike.2. To improve the motion of the boat in storm waves and to reduce drift."His invention as meant to be used with "Bare Poles" and when you are not actively sailing. The series drogue can reduce a boat's speed to 1.5 knots, which does not provide adequate steerage speed for most sailboats in a following sea.You could modify the Jordan Series Drogue by shorting the length and reducing the number of cones to greatly reduce the drag, but the series drogue was really not meant to be used while sailing in a following sea.From the Hathaway, Reiser and Raymond web site, the makers of Galerider:"The Galerider's flow concept through its apertures allows the necessary two or three knots for good steerage control. On the face of the wave it provides elastic but high resistance to eliminate surfing and any tendency to pitchpole. In the trough it provides low resistance, permitting continued steering control. At the same time, Galerider allows the helmsman considerable latitude in setting and maintaining a downwind course of his choosing. This could be of extreme importance, depending on the proximity of land which may represent either hazard or refuge."The Galerider can be used while sailing since it will allow minimum steerage speed while sailing in a following sea. Most Offshore sailors have both a Galerider for sailing in a following sea and some kind of sea anchor.From the makers of "Delta Drogue", Para-Tech Engineering."Speed Limiting DrogueA speed-limiting Drogue is towed off the stern. It's purpose is to (a) limit the boat's speed, (b) reduce her angle of yaw and (c) to provide for steering assist in strong following seas. You can, and may have to, steer the boat with the Drogue in tow. There is a "Catch 22" with any speed limiting Drogue: The same low pull that allows for steering control may also allow the boat to broach, capsize and/or pitchpole in the heaviest seas. The forces that pitchpole yachts are formidable enough to yank the Drogue through the water in the course of throwing the boat end-over-end. Sailors should be aware of this "Catch 22" and make allowances for it in the course of their decisions at sea. WARNING: In all likelihood the insufficient drag of a speed-limiting Drogue will not prevent pitchpole in the heaviest storms, especially those packing ESW's (Extreme Storm Waves), rogues and "Three Sisters" type developments.Four Uses For Drogues1. The above notwithstanding, speed-limiting Drogues can be of immense value in strong following seas and have been used to stabilize craft since antiquity. No doubt there are many yachts sailing today that would have gone down had it not been for the grace of God and some sort of device that slowed the boat down. 2. Towed off the stern with a bridle a speed-limiting Drogue can be used as an emergency steering device to yaw the boat if steering fails. 3. Towed off the windward quarter a speed-limiting Drogue can help maintain directional stability while negotiating a dangerous harbor entrance. 4. Towed off the stern of a vessel in tow a Drogue can all but eliminate the "whiplash" effect and contribute to better control by the towing vessel. "The Delta Drogue in my opinion should be used in moderate sea conditions and the Galerider in extreme sea conditions when you are sailing in a following sea. If you are going to go "Bare Poles" and are not going to be actively sailing, then use a Jordan Series Drogue. If you are going to be actively sailing in a following sea and need a drag device to help you maintain helm control, use either the "Galerider" or the "Delta Drogue". Which one to use will depend on the sea conditions, what size sailboat you have and how you are going to be sailing in the following seas. As stated by others, these are only one sailor's opinions and my not be what you need. The bottom line is to try out different drag devices and see which ones are effective for your sailboat.Fair Winds.Clyde
