Here are my system details:
Compac 23 with a 13.5 gallon fresh water tank.
Outlets are going to be about 10 and 14 feet away from the pump. 1 outlet will be a folding outlet at the slide out sink. The other outlet will be a cold water only cockpit shower in the cockpit.
This means only 1 T in the fresh water line and it will be not too far from where the fresh water hose turns to go out to the folding sink.
What size fresh water pump would you suggest to power these units? 2 or 3 gallon?
I am going to install this system in the fall, I think. I am tired of the pump sink that takes forever to drain the tank when I want it drained and I want a way to have a good shower when I am cruising in the summer. It also makes it easier to wash dished if you have the ability to use both hands and not use one hand to pump the sink. I realize that it is a small water tank and it will drain quickly, but I will keep that in mind when using fresh water. The other thing is that I have plenty of opportunities to fill the tank because I generally use fuel up and refuel every few days.
Thanks for the ideas.
