What size folding cleat for spring lines?
296
Ranger 33 Norfolk
http://cruisermarine.com/accon-stainless-steel-folding-cleats.html
Not advertising, just as an example. . .
The 6" is $47, the 8" is $99. The bow and stern cleats on my 33ft Ranger are 8". Should I pry open my wallet for the folding 8", or would 6" suffice? Is this a good option? The optimal position for a spring line cleat is at the widest beam, about 2/3 of the way back on my boat. . .right in the center of the side deck. Genoa sheets are clipped to the toe rail, so no genoa track cleats. I did think about putting the tracks back in, but I'm unsure if I'd trust that setup to hurricane force winds.
Thanks!
arf145
Nov 4, 2010
498
Beneteau 331 Deale, MD
I'd go with the 8". Those are nice looking folding cleats! I like the fact that you're just dealing with bolt holes and not cutouts.
Apr 11, 2012
324
Cataina 400 MK II Santa Cruz
My centerline cleats are 8". I use them all the time, especially when docking shorthanded. Smaller would not be as good for me.
Beneteau 323 Annapolis MD
Remember, you'd likely have two springs on that cleat, so go for the larger.
Sep 5, 2007
689
MacGregor 26X Rochester
I've never heard of anyone complaining that a cleat is too big, unless it just plain looks out of scale with the boat. When I had a boat with a mid cleat, I'd put the eye splice of one spring line on it, and cleat hitch the other, opposing spring line so the adjustment was how I wanted it, but it takes a full-sized cleat relative to the line size to do that. I would try it with an existing cleat, just to see how the lines fit, and go with a cleat that size if it's a good fit. Or rounded up. Not down.
296
Ranger 33 Norfolk
I stuffed a sock in the mouth of that little voice in my head that always says "no Steve, save a couple bucks now. . .regret it later :stirthepot: " that I always tend to give to much of an ear too. . .
. . .and ordered the 8" cleats. I'll post pictures once I install them.
Thanks!
Blitz
Jul 10, 2007
728
Seidelmann 34 Atlantic Highlands, NJ
8" seems ok for spring lines but if i'd were replacing bow or stern cleats I'd go with 10".
