Jrpla
This is what I have
I have a Beneteau 32 with a Yanmar 2GM13.Equipment I use are:Regular navigation electronics (GPS, radio, autopilot)Norcold Ice Box conversion unit ($600 at defender, 3.3amp/hour when running)Lights, water pump.I have a Xantrex 20+ for shore power charging but this one you will not needed if you are planning to go live away from the dock.I installed a new marine 80 amp alternator on my Yanmar that cost me $90 on ebay. This will charge batteries when running, if needed. I installed a 64 Watt Unisolar NO-GLASS Marine Solar Panel Kit that i found on ebay for $350, this give me 3.5amp an hour.Go to Solar Stick school, here you will learn what system you will need: http://www.solarstik.com/html/school.php , The solar stick is great but too expensive.My batteries, all wet, maintenance free, with a port to add water if needed.1. 1 Group 27 for the motor (use only for emergency)2. 2 Group 31 as house batteries in parallel. (Truck batteries)Golf car batteries are good too buy too much maintenance and too much weight. All my batteries are not marine, and cost me $60 each. I went to a place that sells batteries for trucks and construction equipment. Marine are too expensive and are the same.
