What Size 3 bladed Prop for Universal 11 HP Diesel
montenido
Hi, all. I am currently in the process of buying a 1981 C30 with the small diesel in it. I have been told by more than one C30 owner that some low end power can be gained by installing a 3 bladed prop. Has anybody done this, and if so, where did you find the prop? Any size info woudl be appreciated also. Thanks, montenido
Phil
Catalina
Your best bet is probably to call Catalina and ask them the spec on the proper 3 blade prop.
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Prop
A fixed 3 blade will be the same diameter (13"??) as the 2 blade, but will have less pitch because it will have higher loading. What you will gain with a fixed 3 blade is less vibration, better recovery from loss of speed due to waves, and a slightly better top speed. What you will loose is 1/2 (or more)knot sailing speed.
