In my 1983 H31, the holding tank is a molded-in fiberglass tank in the V-berth. It has a very large cover plate that is held on by a LOT of screws and some sort of caulk or sealant. (Sorry, I don't have a picture.)
The sealant is stained in places, and showing signs of past leaks. As unpleasant as the task may be, I'd like to remove this cover, remove the old sealant, clean and reseal the joint, and re-fasten. I'd rather pay this price now, under controlled conditions and with a pumped and well-rinsed tank, than run the risk of an ugly mess sometime down the road.
What sealant should I use at the joint?
Edit: As I said, I don't have a picture, but the cover is not unlike the cover to the water tank, which you can see a picture of in post #1 of this thread:
http://forums.sailboatowners.com/index.php?threads/1984-hunter-31-persistent-leak-near-fuel-tank.181234/&highlight=water tank cover
