I have a 1985 h23 on which the gooseneck has been located at varying heights during its past life. The goose neck is now mounted with what appears to be 3/16 aluminum domed blind rivets. One of these aluminum rivets looks stretched. I think could just slide a credit card between mast and the upper port corner of the goose neck flange. The rest of the flange sits flush on the mast. A fellow sailor suggested replacing all of the rivets with stainless steel. I'll try to post a picture of the GN this weekend.
Q. Is it 'unsafe ' to sail as is or should it be repaired before going out again?
Q. Should I replace this one 'stretched' rivet now or do all of them??
Q. What do you other h23 owners have on your boat's goose neck?
Q. Has anyone ever moved their goose neck or replaced the rivets because of damage or corrosion?
Q. Does anyone have stainless rivets holding their gooseneck?
Thanks in advance and happy sailing!
Brad
Brad
