What Prop on Hunter -36-356
2,175
Hunter 356 Cobb Island, MD
Just happen to have mine in the basement
It is a 15RH13. Thought you were going to get the Kiwi? What happened, someone make you an offer you can refuse?
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Not Really
15x13 are you sure,the three blade prop on my 36 says 16x9 what kind of rpm's and boat speed do get under power. I have been looking at both trying to make my mind up. Nick
Apr 12, 2005
263
Hunter 36 Cobb Island
H-36 to Florida
Hey seadaddler: When are you taking the boat down to Fla? Are you making the trip offshore? If you will be looking for crew, let me know in advance so I can put in for some vaca!
Mar 21, 2004
2,175
Hey Nick
Yup that is what it said on the prop in two places. I was able to achieve full rated rpm with this prop with no smoke, believe it was around 3500 but not looking real hard at the gage. Normally cruised at 2800 with 6-6.5 kts depending on wind and sea conditions. Get the keel wet on April 5.....
Dec 19, 2006
5,832
Broke sailor and Jim
I am planning to sail down at the end of OCT is the plan so far and mostly off shore but the the exact date is up in the air. I'll be having someone who is very experienced sailing with me so far more details to follow. Broke sailor do you know what prop size is on your 36. Jim my prop says 16x9 which is very different than yours.
Mar 21, 2004
2,175
Nick, engine and transmission is
engine is a yanmar 3GM30 with a 2KM transmission. Is that different than yours. Watch out for Jorge, he is trying real hard for some real sea time and he glows in the dark....;D EDIT: Nick this was the prop from Hunter when I upgraded from 2 - 3 blade.
Apr 12, 2005
263
Hey Seadaddler
I still have what came from the factory. I am leary about changing the prop because I took this diesel maintenance class in NJ with Mack Boring and they said you can kill an engine by putting an oversized prop because the engine then does not run fully loaded, i.e., 80% full rpm. I have 3 weeks vaca in November if you need a deck ape, I am willing and able. I want to experience what a H-36 can do offshore on a OPB (other people's boat). Always wondering if the H-36 will be my retirement boat or do i need to get a more "offshore cruiser".
Shippy
Jun 1, 2004
272
Hunter 356 Harve de Grace
maxprop specs
not that you asked for it, but last year I switched to a max-prop and love it. here is what they recommended for my 03 356....3 Blade 16" diameter by 11" pitch for a 1" shaft
Mar 20, 2004
1,746
either works...
the first 356's shipped with the 15x13 props, and Hunter later switched to the 16x11 without changing anything else. I know because my original dealer installed 15" 3 blade fixed fell off and Hunter replaced it with the 16". Chuck
