Can I use any kind of oil in my Tohatsu 4-Stroke outboard?
For your 4-stroke outboard, you should use Genuine Tohatsu FC-W 4-Cycle Oil. Tohatsu FC-W 4-Cycle Oil is NMMA Certified and has been specially formulated to handle the higher RPM's that outboards are subjected to, as well as special rust inhibitors to combat the harsh operating conditions of the marine environment. Genuine Tohatsu Oil reduces friction & wear and ensures the internal components are properly lubricated for optimum performance. If Tohatsu 4-Cycle Oil is not available we recommend using an NMMA Certified FC-W 4-cycle oil formulated for use in outboard engines. Look for oils bearing the FC-W trademark.
Your Tohatsu 4-stroke outboard is equipped with an Engine Oil Warning Lamp (except for 2hp, 2.5hp & 3.5hp). When the warning lamp is off, it indicates that sufficient oil pressure is present. If the warning lamp is on (red light is on) or blinking on/off, immediately shut down your outboard and check the oil level. Replenish as needed. If the oil level is at the appropriate level and the light continues to stay on or blink, consult your local dealer for assistance (do not use your outboard until a dealer has corrected the problem).
You may notice the engine oil warning lamp come on when you first start your outboard. This is normal and should go off after a few seconds.
I wouldn't go to that trouble. I don't have the manual out, but I think that I remember that it has recommendations for oil other than 'Tohatsu' oil and I'll bet they just put their name on someone else's oil. I just used a good oil.Now I have to call around and see who has the Tohatsu oil.
Thanks
Thanks
The "Tohatsu" label is not as important as the FC-W trademark.If Tohatsu 4-Cycle Oil is not available we recommend using an NMMA Certified FC-W 4-cycle oil formulated for use in outboard engines. Look for oils bearing the FC-W trademark.
All paranoia aside higgs, heres a list of FC-W rated oils that would satisfy Tohatsu's recommendation. I wonder why not owning a refinery makes an oil product lesser than another. It's the "recipe" that matters, not the cook.Never heard of the Tohatsu Refininery. Go online, get the manual for your engine and it will tell you. Of course they want you to use Tohatsu because they buy the stuff and mark it up counting on people being paranoid. Oils all have grade ratings and you only have to use an oil with that particular rating.
Thanks Joe, you converted me to using an oil that is FC-W rated. It might never make a difference, but the outboard uses so little oil that the cost difference is no big deal. I'll get some and replace what we have in the outboard now as it is due for a change,All paranoia aside higgs, heres a list of FC-W rated oils that would satisfy Tohatsu's recommendation. I wonder why not owning a refinery makes an oil product lesser than another. It's the "recipe" that matters, not the cook.
http://www.nmma.org/certification/certification/oil/fc-w.aspx
