What is this?
269
Hunter H260 Gull Lake
While winterizing my H260, I removed all the ropes that were stored in the port locker in the cockpit (under the seat). Inside I found this plastic tube, which is empty inside and some clips. Can someone tell me what these are for, they look factory to me. (Ignore the rope and sponge in the second pic).
Thanks,
704
Catalina 30 Sidney B.C.
Tube looks like it went over rigging turnbuckles and clips are for holding a broom or brush handle
Dec 2, 2003
766
Hunter 260 winnipeg, Manitoba
Can't tell you about the plastic tube, but the clips are to hold your emergency tiller if you have wheel steering. It should be a metal tube with two rings at one end and enlarged at the other end with a groove and hole in it to mount on the top of the rudder stock.
Jun 9, 2008
1,818
- -- -Bayfield
It looks to me like it is a base for a man over board pole. Forespar sold such a device. But, if your boat doesn't have a MOB pole, then someone may have used this as an extension for the tiller handle on a dinghy outboard. I purchased a PVC tube to slip over the tapered tiller handle on my dinghy outboard so I could sit further forward in the dinghy so it would plane off quicker.
Nov 6, 2006
10,164
Hard to get a feel for the size .. A manual bilge pump handle? a fish billy club? Seat hatch prop to keep it open? Looks like about 1" PVC with a pipe cap on one end and the other end open.. ?? I dunno
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
Trailer roller
Looks a little like the trailer rollers that go on the goal posts.
