OK, it is a little more than the weight that I need help with. Here is a copy of the info,
Variables are as follows:
Wmast - mast weight, taken at the center of gravity
MAmast - moment arm of the mast about the hinge
MAhoist - moment arm of the mast raising hoist about the hinge
MAhalyard - moment arm of the jib
halyard about the hinge
The total tension force in the hoisting system is easily calculated by summing moments about the mast hinge, and setting it equal to zero (static equilibrium).
M = 0 = Wmast*MAmast - Fhoist*MAhoist where Fhoist is the tension force in the hoisting system
I have figured MAhoist with 5,6,&7 foot poles.
But am unable to see how to get the Fhoist figure.
How is Fhoist determined?
