Pete...Why Not To The Stern??
Pete, in your response you said to run the bilge hose to the hull sides, as high as possible, and not to the stern. I can certainly see why you want it high, to overcome heeling angles. But why not to the stern? By running it to the stern you get around the heel problem, thus you can mount it lower, thus getting around the bilge hose, "head" height problem, and the need for a higher capacity pump to overcome the height the hose must exit. My bilge hose exits my stern (25 ODay), a few inches above and to the right of my cockpit drain, which is about 1 foot above waterline, near to deadcentre. I have had no problems with this configuration.Don
