Jack
I have a Catalina 27 and feel that the prop may be undersized. I would like to realize more power while motoring. Even though I do not race I like to go as fast as possible while under sail, therefore drag is also a concern. Here are my boats particulars:Displacement 6,850 lbsWaterline Length 21' 9"Engine: Universal Diesel M18, 14 Hp @ 3200 RPM, 2:1 reductionCurrent Prop: 2 blade 13 x 10 RHPI performed some calculations following an article in this months Sail magazine and the results say that I should have a prop that is 21" in diameter (that is the figure not taking into account reduction. I would not be able to fix a 21" prop in any case).If, after taking into account my specs find that my current prop configuration is indeed inadequatecan you reccomend an appropriate 2 blade and 3 blade prop configuration. I would also be interested in your comments on pros and cons of both configurations.Thank you
