what is the best oil to use in a yanmar 3QM30H
27
Hunter 1983 Cherubini 37 Cutter Solomons, Md
Hi,
Do you all check your oil and transmission fluid prior to every use and what do you find to be the best oil and transmission fluid to use?
Thanks as always for your helpful responses.
Jim
Dec 2, 1999
15,184
Jim: I think that Yanmar recommended 30WT oil when those engines where built. We use Chevron Delo, but there are many sailors who recommend the Shell products.
You want to be sure that you use an oil that is recommended for Diesels (this is a Cx rating). As for your transmission, you need to see what Yanmar spec'd for your transmission. If you look at Yanmar Help. Com they have a table with all the different transmissions listed.
PS: I think that Yanmar now recommends multigrade oil for their engines, so the choice is yours.
Jun 21, 2007
2,118
Jim:
Soon after I purchased my boat three years ago, I posted on the "Ask All Sailors" forum your very question about the "every time" check of oil. Got a range of answers, from "most definitely" to "why ... where's the oil going to go since your last shutdown and what do you expect to find everytime?" I would think that the answer is it depends on your comfort level. If you are using your boat frequently and the engine mostly for short periods just to get in and out of the harbor, then say a check once every week or so = once every several times out is enough, which is what I do. Not too many people check their car's oil every time its driven (if ever). If you only go to the boat say once a month, then a check everytime will give peace of mind and also will prompt a general look-see around the engine for general condition of hoses, coolant levels, a check for fluid in the catch area under the engine, etc.
Another area of widely varying opinion is the need for a new oil filter with every oil change. My Yanmar manual specifies an oil change every 100 hrs, but a filter change every 300 hrs. A lot of people will opine that a new oil filter with every oil change is a must ... nothing but the best practice for an expensive engine ... cheap insurance. But as I've done with cars since a teenager, I change the filter every other oil change. Not because of cost, but changing filters can be messy and depending on the car necessitates putting it on stands to get at the filter. With modern engines, I also think that quality of manufacturing and tight tolerances greatly limit the amount of carbon blow-by and metal shavings that might be flowing through the oil and caught in the filter. I've never had a mechanical engine breakdown in the 40 years I've owned cars and motorcycles. And I generally own each one for 10 years or more. And the many times I've taken the valve cover off for valve clearance adjustments, I've never seen any buildup of sludge. So I'm doing the filter every other time with my boat's Yanmar as well.
