What is the best boat soap?
Big Joe
Sorry to post what to some may seem a trivial subject. I am interested in knowing what you consider is the best boat soap? My boat gets dirty easily as we are in the LAX flightpath. Any recomendations on what gets a dirty boat clean with the least effort? I know it's not going to clean itself and there is work involved but what makes it easier? Thanks for any suggestions. Big Joe
Dec 2, 1999
15,184
Island Girl Pink!
Joe: Get a bottle of Island Girl Pink. This stuff works well on hard to remove grit & grime. I mix a little in a bucket of warm water and scrub the decks. If I have some stubborn spots I have some diluted strength in a spray bottle to help lift the tough spots.
Ross
Jun 15, 2004
14,693
I just use Top Job the same as I use for the kitchen floor
in my house. But mostly I just use water dipped up from the river beside the boat with a bucket.
May 17, 2007
180
HUNTER 25.5 St. Augustine
Boat soap?
The best Boat Soap? Well that would have to be....TIDE! (sorry, I just couldn't resist!)
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
My vote goes for diluted bleach
But I also have good luck with Simple Green. Manny
May 11, 2005
3,431
Seidelman S37 Slidell, La.
I have a problem
My biggest problem is bird poop. The like to roost on the spreaders. Also have a problem with blue herons walking around on deck, and when they go, man they go. I use a little liquid dishwashing soap, with a little bleach mixed in. Works as good as anything I have found. There is no magic elixir, and some elbow grease is required.
Dave
Arm and Hammer
I found that Arm and Hammer powder laundry detergent with no fragrance or dye is excellent for cleaning decks and bleaching weathered teak. It is touted as being bio-degradable. That said, even bio-degradable detergents can be harmful to fresh water. They are less harmful to salt water where they break down faster. I use about 1/4 cup to 3 gallons of warm water. Wash small areas and rinse often.
Feb 12, 2007
259
Ericson 25 Oshkosh, WI
Magic Elixer
I posted this a week or so ago. Greased Lightning is the " bee's knee's ". I wet the boat and spray GL, open a beer, drink half of it. I then grab the hose and wash down and its clean. Those little spider poo dots drool away, bird crap erodes. Greased Lightning is "dirt" cheap! Its worth a try. You will be satisfied. Rob Hessenius
Feb 6, 1998
11,701
That's a very loaded question
First you need to decide if you want your boat easy to clean in the future. If you do, a good deck wax like Woody Wax will be required first. Soap options for a waxed boat include "West Marine Crystal Boat Wash" and IMAR Yacht Soap Concentrate (#401). These are the only two soaps that I have found not to destroy or eat a waxed finish and the Imar is the least offensive to the wax yet it still does an excellent job. If you don't wax your boat any soap mentioned will work but be careful with some of the suggestions mentioned as they can be harmful to metals and aluminum, dodger windows and acrylic or lexan....
RichH
Feb 14, 2005
4,773
Ditto Maine's recommendation
I use Maguires Deep Crystal Car Wash .... it doesnt dissolve the wax on the boat. Most 'soaps and detergents' especially if the are the least bit 'caustic' will dissolve wax.
Big Joe
Thanks to all resoponders
Thanks so much for the suggestions mates. I appreciate you all. Regards, Big Joe
Sep 20, 2006
155
Hunter 49 Mystic CT
Woody Wax Ultra-Pine is my choice
I'm a big fan of most of the Island Girl Products but I don't find Pink as a very satisfactory general cleaner. It's great for spot cleaning though. The best boat soap I have found is Woody Wax ultra - pine. Very pleased with this product but a bit pricey as boat soaps go. However a little bit goes a long way.
RichH
Feb 14, 2005
4,773
Thanks DWJ
never thought about a fungicide / antibacterial in boat soap. Would certainly help retard the growth of mildew and that damn 'artillery fungus' (those damn 'black specks') that grows all over Chesapeake berthed boats in spring. Gotta try some. The typical antibacterials in 'soap' aren't true antibiotics but cellulose derivatives that are fairly 'bio-safe' for the environment, etc. thanks for the info/posting.
