I'm thinking of selling my 1984 M25 but need some input on what you folks think it may be worth. I bought it two years ago after it had been sitting for 15 years and was in need of a total restoration. I have done a ton of work to bring it back to life and really have enjoyed sailing it for the last two years. Here is a copy of the ad I was posting to craigslist. Please let me know what you think I should be asking.
Like any boat there are always things that you can do to make it better or more useful for the way you plan to use it. There are some normal scratches and chips in the gel coat for a boat this age which I refilled with gel coat but no damage to the fiberglass. I didn't spend a lot of time repairing them as summer came and it was time to get it out on the water. I also need to install a connector in the top of the cabin for the used VHF radio I installed.
A couple of things I also did that I did not list in the ad was remove all the foam and clean and painted them to seal them and reinstalled.
1984 Macgregor M25 sailboat. Boat is in very good condition and is ready for a late season sail. The main and jib sails are in very good condition with no tears or damage with a sunbrella main cover. The keel is a retractable cast iron keel which I sandblasted to bear metal and refinished with Interlux primer, four coats of Watertite filler to fair to proper shape and then four coats of marine epoxy. Installed a new keel winch and cable and replaced pivot and lock bolts and all hardware. Trailer was stripped and treated with PRO15 and then top coated and new bunks and trailer winch installed. All new wheel bearings, glavanized wheels, new tires and bearings buddies installed.
I also removed all the deck hardware and resealed and reinstalled with stainless steel backing plates. New swim ladder and LED anchor and cabin lights installed with both red and white bulbs. Has a brand new never used freshly serviced Sanipottie 962 installed in the enclosed head. Sleeps five in the cabin and all the cushions are in excellent condition with no tears or stains. Has a pop-top cabin with a like new condition canvas with windows to enclose to give you standup cabin room.
This boat is very easy to trailer and setup and with the keel retracted only needs 18" of draft so can go in close to shore or in a small cove where other sailboats could never go. I made a mast raising system that makes it easy for one person to raise and rig the mast.
It has a 1985 9.9 hp Yamaha four stroke which is in excellent condition and runs perfect. It has all new fuel lines on the engine and tank with a new 3.5 gallon fuel tank.
Comes with the following equipment:
2 ea dock lines (new last year)
All required Coast Guard required equipment.
4 ea new lifevests in case.
1 ea boat hook
5 ea fenders.
VHF radio with antenna.
Removable cabin sink.
Bow pulpit and life lines
Wind indicator.
New main halyard this year
Stainless mast organizer.
Anchor, chain and line.
Swim ladder.
If you search for jjsbiggs on this site there are lots of posts of the work as I was doing it. You guys were a great help while I was restoring it and I really can't thank you enough for all the advice.
1 ea boat hook
5 ea fenders.
Wind indicator.
Swim ladder.
